Webcast-Catalyst9k
827 DSL Problems
I have a Cisco 827 router that has worked great for us for the past two years. It has always brought in the 1.5 Mbps DSL into our corporate LAN without a hitch. Three weeks ago things changed. I tend to think the router is still great and that it is our ISP (TDS Telecom) that has gone to hell, but I'm posting here to get your feedback.
Three weeks ago, November 23 to be exact, we started losing our Internet connection at 5 PM, plus or minus a minute. Our Internet is gone and it stays gone until about 5 AM. Between 5 AM and 5 PM everything is great, strong, and solid. Every week day the same thing happens. As far as I have been able to tell Saturdays are out of service, but then Sundays are usually on.
When we lose our Internet the OK, CD, and 1 lights are on solid. No other flickering or solid lights are to be seen. It looks like we should have service, but we don't. We can ping the router at anytime from the LAN, before or after 5 PM.
The common thought from our ISP (who refuses to step on site) and independent CCNA/MCSE (who came on site and spent about two hours after 5 PM troubleshooting to only scratch his head) is that there must be a point of interference that is kicking on at 5 PM and shutting off at 5 AM. We run two shifts here, but the shift change is at 3:30 PM, and we have changed nothing around here in months with equipment, electrical work, or the sort. We've spoken with our nearby neighbors to see if they brought on any new equipment or processes three weeks ago and that has come up empty.
I am not a CCNA, nor an MCSE, but I do have an engineering degree and seven years of IT experience. This whole situation is getting a lot of people hot and I'm looking for any possible answers or things to try. Thanks for your feedback.
Re: 827 DSL Problems
Somewhere in your ISP's network, they must be shutting something down as it seems to be routinely doing this.
To conclusively prove this, do a traceroute to an internet site when you internet is up and working.
Capture the traceroute and do a couple more. This way you will see a general route through which your trace goes.
After 5pm, do another traceroute to the same destinations and notice where it stops.
I will almost bet that it will be somewhere in your ISP's network and you will have proof of it too.
If it stops at your router, given that nothing has changed as you mentioned, the next hop(I imagine to be your ISP) can only be the source of the problem.
Hope that helps?
Let me know?
Andrew Morris
Has someone configured the router ignore outgoing traffic for a 12 hour period and forgot to let everyone know! Can you post the running configuration here? Use "Router#sh run" command and cut and paste the info here and I'll take a look at it, your CCNA friend should know what to look for (Replace your ip addresses and passwords with x's)
To update the situation, we now have Internet access 24 hours per day again. Last Friday a TDS technician came out, found nothing, and yet that evening our Internet remained on after 5. TDS has not acknowledged that they fixed the problem. In fact, they think we still have the problem. Until we get a proven record of success going I'm not going to tell them any different. Take a look at our config below. Tell me if you see anything out of the ordinary. One thing I would like to change is that as things are currently set up, we can not ping or run traceroutes on external addresses. What do I need to change to enable this? Why would our CCNA default to not enabling this? Thanks for your time.
ABS827#show run
Building configuration...
Current configuration : 1914 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
no service dhcp
hostname ABS827
enable secret 5 ZZZZZ
enable password 7 ZZZZZ
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip name-server X.X.X.X
no ip dhcp conflict logging
interface Ethernet0
ip address X.X.X.X X.X.X.X
ip nat inside
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/100
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
hold-queue 208 in
interface Dialer0
description ip address from TDS X.X.X.X
bandwidth 1544
ip address negotiated
ip access-group 101 in
ip nat outside
encapsulation ppp
dialer pool 1
ppp pap sent-username password 7 ZZZZZ
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static tcp X.X.X.X 3389 X.X.X.X 3389 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
access-list 1 permit X.X.X.X
access-list 101 permit tcp any any established
access-list 101 permit udp host X.X.X.X any
access-list 101 permit tcp host X.X.X.X any eq telnet
access-list 101 permit udp host X.X.X.X host X.X.X.X eq snmp
access-list 101 permit udp host X.X.X.X host X.X.X.X eq snmptrap
access-list 101 permit tcp any any eq 3389
access-list 101 deny ip any any
snmp-server engineID local ZZZZZ
snmp-server community chorus-public RO
line con 0
exec-timeout 20 0
password 7 ZZZZZ
login
stopbits 1
line vty 0 4
exec-timeout 0 0
password 7 ZZZZZ
login
scheduler max-task-time 5000
end
ABS827#
Bronze
Hi, cut and paste the following to your 827. This will allow echo reply and traceroute back in through your dialer interface.
conf t
no access-list 101
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any traceroute
end
Your config looks ok. No reason for the time based problems you have been experiencing.
hth
I spent 4 1/2 years in a DSL NOC. Youre problem is not the router, the config or anything. Its your DSL line. Signal interference with DSL lines is common and very well known. TDS is your ISP, but it looks like Covad is your DSL providor. You need to verify this with TDS, and if you still have line problems you need a Covad line tech dispatched to your site with a TDR for intrusive testing after 5pm.
My guess would be that somethign in your area was installed on Nov 22 or 23rd. They may want to invesitgate that also.
Going with your line of thinking, does it make sense that a neighboring company in another building less than 100 yards away with the same DSL service and the same Cisco router has had no service interuptions this past month? Forgive the newbie questions, but what is your indicator that Covad is our DSL providor? What is a NOC? What is a TDL?
97
