827 pppoe Dynamic ip with webserver
I use a Cisco 827 router with PPPoE with a dynamic ip address from the provider.Everything 's working fine, but now i would lijke to install a webserver. Therefor i have to do on portforwarding because the router is configuerd in NAT. I did everything right (i think) but i can't connect my webserver from outside.
However with an Alcatelrouter everything is working well.
Were 's my problem??
Here is my config. My webserver is 192.168.254.5
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname ADSL
enable secret xxxxxxxxxxx
username ADSL password xxxxxxxx
username xxxxx password xxxxxxxxxxxx
ip subnet-zero
ip name-server 195.238.2.22
ip name-server 195.238.2.21
ip dhcp excluded-address 192.168.254.254
ip dhcp excluded-address 192.168.254.5
ip dhcp pool CLIENT
import all
network 192.168.254.0 255.255.255.0
default-router 192.168.254.254
lease 0 2
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
interface Ethernet0
ip address 192.168.254.254 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
hold-queue 100 out
interface ATM0
no ip address
atm vc-per-vp 64
no atm ilmi-keepalive
--More--
pvc 8/35
pppoe-client dial-pool-number 1
dsl operating-mode auto
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer remote-name redback
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname xxxxxxxxxx
ppp chap password xxxxxxxxxxxxxxx
ppp pap sent-username xxxxxxxxxxx password xxxxxxxxxxx
ppp ipcp dns request
ppp ipcp wins request
ip nat inside source list 102 interface Dialer1 overload
ip nat inside source static tcp 192.168.254.5 80 interface Dialer1 80
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
access-list 23 permit 192.168.254.0 0.0.0.255
access-list 102 permit ip 192.168.254.0 0.0.0.255 any
dialer-list 1 protocol ip permit
line con 0
stopbits 1
line vty 0 4
access-class 23 in
exec-timeout 120 0
login
length 0
scheduler max-task-time 5000
end
Re: 827 pppoe Dynamic ip with webserver
Your config looks fine from what I can see, but here's a couple of things to try.
First, try adding the key word extendable to the static line, ie:
ip nat inside source static tcp 192.168.254.5 80 interface Dialer1 80 extendable
The only other thing I can think of is if you had added your static translation to the config and didn't reload the router or do a clear ip nat trans * after making the change. This could cause it not to work because the Dialer1 overload translation would still be in effect for your web server.
Hope it helps -
Bob
Hi Bob,
I tryd to add the "extendable" at the end of the static command line but it i recieved an invalid input at the word extendable.
The second thing you was no succes either.
I took a look on the site and found an example of a config but it looks the same as the one i 'm using.
Still any suggestions.
Thanks.
Jim
211
