827 with PPPoE-Bell South
I have an 827-4v and am running into problems installing with PPPoE with Bell South. Does anyone have a working config using PPPoE, or better yet, a config for Bell South.
Your help will be greatly appreciated.
Thanks!
tepatel
Leet us know what type of problems you are facing..But You will find a sample config for 827 router as a PPPoE client at...
http://www.cisco.com/warp/public/794/827pppoe_client.html
For 827 troubleshooting guide, visit
http://www.cisco.com/warp/public/794/827_lyr1.html
http://www.cisco.com/warp/public/794/827guide.html
I have a Carrier Detect, however, I am not receiving atm cells. I assume I would receive cell from the WAN side, even if my PPPoE and CHAP failed. It is not the ISP/Bell South as it functions with an extenal modem and D-Link Router.
Here is my config - I based it on one in my area that is currently working with Bell South.
Can you see any mistakes?
Albert827#sh run
Building configuration...
Current configuration : 1565 bytes
version 12.1
no service single-slot-reload-enable
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Albert827
logging rate-limit console 10 except errors
enable secret 5 $1$h/UC$6jnaRVt59RzRwqxLMHeML.
enable password 7 0707
username albert password 0 0707
ip subnet-zero
no ip finger
ip dhcp excluded-address 192.168.0.1
ip dhcp pool client
import all
network 192.168.0.0 255.255.255.0
default-router 192.168.0.2
dns-server 205.152.144.252
no ip dhcp-client network-discovery
call rsvp-sync
interface Ethernet0
ip address 192.168.0.2 255.255.255.0
ip nat inside
no cdp enable
hold-queue 32 in
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/16 ilmi
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
bundle-enable
dsl operating-mode auto
hold-queue 224 in
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname miami65@bellsouth.net
ppp chap password 7 0707
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
ip nat inside source list 101 interface Dialer0 overload
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
dialer-list 1 protocol ip permit
no cdp run
voice-port 1
voice-port 2
voice-port 3
voice-port 4
line con 0
exec-timeout 120 0
transport input none
stopbits 1
line vty 0 4
exec-timeout 120 0
password 7 0707
login local
no scheduler max-task-time
end
YES..You will receive the ATM cells even of the PPP fails or so..Pl. turn on the debug
debug atm packets
debug atm events
Now "shut" and "no shut" on the atm interface and see what debug reports..Thx..Tejal
I cannot see the following mandatory commands in your config.
vpdn enable
request dialin
protocol pppoe
You need this commands for it to work.
You can also try using built-in web configuration tool to configure it. [You can also configure PAT, Firewall etc..] through this tool If you need any furthur info on the tool, contact me.
