827H ip/fw ios - dsl operating-mode auto
I have a 827h router running the ip ios (c820-oy6-mz.122-4.YA2.bin). This works fine.
If however i upgrade the ios to include the ip/fw/des ios (c820-k8osy6-mz.122-2.T4.bin) it immediately stops working. the atm0 interface shows down and line protocol down.
I have tried all the obvious things to no avail. One thing i have noticed is that in config mode if i change to the atm0 interface I have no option to enter commands starting with 'dsl' the main one that i have noticed is missing is "dsl operating-mode auto". This is a command that i have seen in every sample config posted on cisco.com and on other sites.
Router Config
version 12.2
no parser cache
service single-slot-reload-enable
no service pad
hostname KahunaRO
logging buffered 4096 debugging
logging rate-limit console 10 except errors
username pagec password 0 xxxxxxxxxxxx
ip subnet-zero
ip inspect name Dialer_0 tcp
ip inspect name Dialer_0 udp
ip inspect name Dialer_0 cuseeme
ip inspect name Dialer_0 ftp
ip inspect name Dialer_0 h323
ip inspect name Dialer_0 rcmd
ip inspect name Dialer_0 realaudio
ip inspect name Dialer_0 streamworks
ip inspect name Dialer_0 vdolive
ip inspect name Dialer_0 sqlnet
ip inspect name Dialer_0 tftp
ip ssh time-out 120
ip ssh authentication-retries 3
no ip dhcp-client network-discovery
interface Ethernet0
ip address 192.168.xxx.200 255.255.255.0
ip access-group 102 in
ip nat inside
interface Virtual-Template1
no ip address
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Dialer0
bandwidth 640
ip address xxx.xxx.xxx.xxx 255.255.255.0
ip access-group 101 in
no ip redirects
no ip unreachables
ip nat outside
ip inspect Dialer_0 out
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname me@mydsl.net
ppp chap password 7 141C1D05030C2B
ppp ipcp dns request
ip nat inside source list 1 interface Dialer0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
access-list 1 permit xxx.xxx.xxx.0 0.0.0.255
access-list 23 permit xxx.xxx.xxx.0 0.0.0.255
access-list 101 remark Traffic allowed to enter the router from Internet
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip any host 255.255.255.255
access-list 101 permit udp any eq isakmp any eq isakmp
access-list 101 permit gre any any
access-list 101 permit icmp any any unreachable
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any packet-too-big
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any traceroute
access-list 101 permit icmp any any administratively-prohibited
access-list 101 deny ip any any log
access-list 102 remark Traffic allowed to enter the router from the Ethernet
access-list 102 deny udp any any eq tftp
access-list 102 permit ip xxx.xxx.xxx.0 0.0.0.255 any
access-list 102 permit ip any host xxx.xxx.xxx.254
access-list 102 permit ip any host 255.255.255.255
access-list 102 deny ip any any log
dialer-list 1 protocol ip permit
line con 0
stopbits 1
line vty 0 4
login
scheduler max-task-time 5000
end
Does anyone have any advice on what could be causing this and if there are any workarounds.
any help/advice would be apreciated as this is driving me nuts
Bronze
Re: 827H ip/fw ios - dsl operating-mode auto
The H model uses a different ADSL chipset than the 827 (newer version), so the "T" train is not yet supported. This setup should work fine with any 12.2(4)YA or newer code.
Aaaah so that's it - I logged a case with TAC after I found that it would work with YJ or YJ1 and not T4/T5 but got nowhere fast.
Thanks a lot, that worked a treat. I've been tearing my hair out over this.
chris
154
