831 Router with PPPoE - No Dialer String error
I've been trying to use a config template that appeared in this forum to configure PPPoE client on
an 831 to connect to an ADSL ISP. When I try to connect to the ISP the 'debug dialer' output is:
*Mar 2 03:07:29.629: Di1 DDR: Cannot place call, no dialer string set.
Anyone know what I'm doing wrong ?
I'm using IOS 12.2(13)ZG
The config in use is:
______________________________________________
version 12.2
no service pad
hostname Router
logging buffered 4096 debugging
enable password cisco
ip subnet-zero
no ip domain lookup
ip urlfilter alert
ip audit notify log
ip audit po max-events 100
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
interface Loopback1
ip address 10.10.10.1 255.255.255.255
interface Ethernet0
ip address 10.220.46.96 255.255.255.0
ip nat inside
no ip route-cache
no ip mroute-cache
hold-queue 100 out
interface Ethernet1
no ip address
no ip route-cache
no ip mroute-cache
duplex full
pppoe enable
pppoe-client dial-pool-number 1
hold-queue 100 out
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap
ppp pap sent-username user@domain password encr-pass
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
line con 0
password *******
no modem enable
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password ******
login
scheduler max-task-time 5000
end
VIP Purple
Re: 831 Router with PPPoE - No Dialer String error
try to add the following to your (global) configuration and see what happens:
ip nat inside source list 101 interface Dialer1 overload
access-list 101 permit ip 10.220.46.0 0.255.255.255 any
GP
I've added this but still no luck...
Still getting the following debug output:
I think you have to configure a dialer string. number doesn't matter.
try to add on dialer interface:
dialer string 555
ppp authentication pap callin
ppp ipcp dns request
ppp ipcp wins request
regards
420
