Webcast-Catalyst9k
837 ADSL Problem
I am trying to configure an 837. It works fine when I configure it using CRWS. However, when I use the SDM, I am unable to connect to the Internet. When I debug dialer events, I get the following error
UTC: Di0 DDR: Cannot place call, no dialer string set
What does this mean?? I have configured another 837 at the customers other site and it works fine.
Graham
Bronze
Re: 837 ADSL Problem
The dialer string is the number needed to dial the destination. For DSL, it might be the VPI/VCI needed to communicate. You can use the 'show running-config' command to check the difference in the configuration while configured with CRWS and SDM. This could be an issue with the hardware/software version that you are using. Check this link :
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/826/swg/routconf.htm
VIP Purple
Hi Graham,
have you used CRWS before you started using SDM on the same router ? If that is the case, I assume you have followed the switchover procedure ?
Can you post the config of the router ?
Georg
I have followed the switch over. I think my problem now is that the exchange is different. This is because I can take the router to another ADSL circuit and it works fine configured under SDM. The main difference between the configs is the encapsulation, PPPoA and PPPoE.
The reason why I want to use the SDM is so that I can configure Site to Site VPN. I tried doing this through the CLI but it would not accept some the Crpto commands. Anyway, here is my config.
TTUpminster_ADSL#sho run
Building configuration...
Current configuration : 2533 bytes
version 12.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname TTUpminster_ADSL
logging queue-limit 100
logging buffered 51200 debugging
logging console critical
enable secret xxxxxx
username xxxxx privilege 15 password xxxxx
ip subnet-zero
no ip source-route
ip tcp synwait-time 10
ip domain name dslconnect.co.uk
ip name-server x.x.253.50
ip name-server x.x.253.58
ip dhcp excluded-address x.x.2.1 192.1.2.50
ip dhcp excluded-address x.x.2.81 192.1.2.254
ip dhcp pool sdm-pool1
network x.x.2.0 255.255.255.0
default-router 192.1.2.47
domain-name dslconnect.co.uk
dns-server x.x.x.50 80.225.253.58
no ip bootp server
ip cef
ip audit notify log
ip audit po max-events 100
ip ssh time-out 60
ip ssh authentication-retries 2
no ftp-server write-enable
interface Ethernet0
description $FW_INSIDE$$ETH-LAN$
ip address x.x.x.47 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1452
hold-queue 100 out
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 0/38
pppoe-client dial-pool-number 1
interface Dialer0
ip address 80.46.xxx.xxx 255.255.255.0
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname xxxxxxxxxxx_tsl@dslconnect.co.uk
ppp chap password xxxxxxx
ip nat inside source list 1 interface Dialer0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
logging trap debugging
access-list 1 remark INSIDE_IF=Ethernet0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.1.2.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!
^C
line con 0
login local
no modem enable
transport output telnet
stopbits 1
line aux 0
login local
stopbits 1
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler interval 500
end
The config does not look correct to me. It should be something like this:
vpdn enable
no vpdn logging
vpdn-group pppoe
request-dialin
protocol pppoe
pvc 1/1
interface Dialer1
ip address negotiated
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1 <--- ties to atm interface
ppp chap hostname client1
ppp chap password 7 020508520E081B70
216
