837 dsl speed problems
Just installed an 837 adsl router at a customer site. Previous they were using a cheapo dsl modem provided by the dsl provider, they were getting 1.5MB down and 512k up. After putting in the Cisco 837 I'm only getting 800k down and 128k upk, what am I missing here?
Scott
  • Other Network Infrastructure Subjects
Silver
Re: 837 dsl speed problems
check the CPU load , if its overloaded, it is due to process switching.
You can configure for IP cef globally by configurinh the command "ip cef"
Thanks for the suggestion. Turns out that the telco had "adjusted" speeds for many of their customers while I was installing this router. Basically they screwed up and reduced the customer's speeds, nice timing, eh?
112
