02-17-2006 03:59 PM - edited 03-03-2019 01:53 AM
hi, im trying to configure my 871 router, in the online manual (http://www.cisco.com/en/US/products/hw/routers/ps380/products_configuration_guide_chapter09186a008045d249.html#wp1137813) it says: Router# show running-config but how can I connect to the terminal port in order to telnet the cisco?
I plugged a rj45 cable between the port and my nic's pc... and it has no connecivity... or must I use a dummie terminal or some like that in order to get connected to the shell terminal?
thanks in advance.
02-17-2006 04:53 PM
It should have came with console cable. You need to console into the device.
02-17-2006 09:47 PM
If you need to make a console cable, follow the cabling pinout requirements in the following document:
Hope that helps - pls rate the post if it does.
Paresh
