A 3524 xl auto reboot problem
run ios version:12.0(5.1)XP
when boot.it display:
C3500XL POST FAILURE: front-end post: FastEthernet0/1:
C3500XL POST FAILURE: looped-back packet not received
C3500XL POST FAILURE: front-end post: FastEthernet0/2:
C3500XL POST FAILURE: front-end post: FastEthernet0/3:
C3500XL POST FAILURE: front-end post: FastEthernet0/4:
C3500XL POST FAILURE: front-end post: FastEthernet0/21:
C3500XL POST FAILURE: front-end post: FastEthernet0/22:
C3500XL POST FAILURE: front-end post: FastEthernet0/23:
C3500XL POST FAILURE: front-end post: FastEthernet0/24:
C3500XL POST: MII Test: Passed
cisco WS-C3524-XL (PowerPC403) processor (revision 0x01) with 8192K/1024K bytes
of memory.
Processor board ID 0x12, with hardware revision 0x00
Last reset from warm-reset
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
16 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:01:42:4F:A4:80
Motherboard assembly number: 73-3904-08
Power supply part number: 34-0851-02
Motherboard serial number: FAA04069EUD
Power supply serial number: PAC040402TL
Model revision number: A0
Model number: WS-C3524-XL-EN
System serial number: FAA0409J03Y
Press RETURN to get started!
C3500XL INIT: Complete
00:00:24: %SYS-5-CONFIG: Configured from NVRAM by console
00:00:24: %SYS-5-RESTART: System restarted --
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5.1)XP, MAINTENANCE IN
TERIM SOFTWARE
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Fri 10-Dec-99 11:16 by cchang
%Software-forced reload
Preparing to dump core...
00:04:107374182399: %SYS-2-WATCHDOG: Process aborted on watchdog timeout, proces
s = GDS Frame Ager.
-Traceback= 1C4C24 1C64CC 1BFAEC
Queued messages:
Exception (8192)! Debug Exception (Could be NULL pointer dereference)
CPU Register Context:
Vector = 0x00002000 PC = 0x001BE2A0 MSR = 0x00029200 CR = 0x22000020
LR = 0x001BE294 CTR = 0x00139CD0 XER = 0x00007F41
R0 = 0x001BE294 R1 = 0x00498BCC R2 = 0x00000000 R3 = 0x003D74E8
R4 = 0xFFFFFFFE R5 = 0x00000000 R6 = 0x00443ACC R7 = 0x00000000
R8 = 0x003D0000 R9 = 0x00429FDC R10 = 0x00000000 R11 = 0x00043350
R12 = 0x28000020 R13 = 0x00000000 R14 = 0x00000000 R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000FA0
R24 = 0x00006000 R25 = 0x00000000 R26 = 0x004F56C0 R27 = 0x00000000
R28 = 0x71000420 R29 = 0x00000000 R30 = 0x00000000 R31 = 0x00000000
Stack trace:
PC = 0x001BE2A0, SP = 0x00498BCC
Frame 00: SP = 0x00498BDC PC = 0x001BE294
Frame 01: SP = 0x00498BEC PC = 0x001C4CC8
Frame 02: SP = 0x00498C04 PC = 0x001C64CC
Frame 03: SP = 0x00498C50 PC = 0x001BFAEC
Frame 04: SP = 0x00498C88 PC = 0x00000000
Frame 05: SP = 0x00498CA8 PC = 0x000EAF28
Frame 06: SP = 0x00498CD8 PC = 0x000E940C
Frame 07: SP = 0x00498CF8 PC = 0x000E960C
Frame 08: SP = 0x00498D18 PC = 0x000CE7A0
Frame 09: SP = 0x00000000 PC = 0x001C5474
and then the system warm reboot.
someone can help me?thx a lot!
  • Other Network Infrastructure Subjects
Re: A 3524 xl auto reboot problem
It seems to me that you have a hardware failure.
POST errors on the ports refer mostly to the hardware.
You should send your switch for replacement or repair.
OH.thx very much.
338
