a 36's serial interface's IP couldn't pinged through from the same router
IOS (tm) 3600 Software (C3640-JS-M), Version 12.0(4)T, RELEASE SOFTWARE (fc1
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Thu 29-Apr-99 15:06 by kpma
Image text-base: 0x600088F0, data-base: 0x60DCA000
ROM: System Bootstrap, Version 11.1(20)AA1, EARLY DEPLOYMENT RELEASE SOFTWARE
c1)
ROM: 3600 Software (C3640-I-M), Version 12.0(3)T3, RELEASE SOFTWARE (fc1)
config:
interface Serial3/3
ip address 10.160.24.1 255.255.255.252
no ip directed-broadcast
encapsulation ppp
ppp quality 80
from the router:ping 10.160.24.1. never success!!!!
help please,emergency. many thanks
Re: a 36's serial interface's IP couldn't pinged through from th
1) have you issued the "no shut" command? :)
2) is there any router on other end of the ppp link? if there is no router, you will (afaik) never get any answer.
3) in which state is your serial3/3? could you give us `sh int s3/3` ?
4) are you getting any answer with `no ppp quality` ?
GL
1)and 2) are just right;
3) see here pl.:
KWE-C36-SN1A#sh int s3/3
Serial3/3 is up, line protocol is up
Hardware is CD2430 in sync mode
Internet address is 10.160.24.1/30
MTU 1500 bytes, BW 128 Kbit, DLY 20000 usec,
Encapsulation PPP, loopback not set
Keepalive set (10 sec)
LCP Open
Listen: CDPCP
Open: IPCP
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 22:34:05
Input queue: 1/75/0 (size/max/drops); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/3/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
6540 packets input, 439597 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
9849 packets output, 814565 bytes, 0 underruns
0 output errors, 0 collisions, 2189 interface resets
8 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
btw.one thing to mention: the interface worked well and i can ping through the opsite ip 10.160.24.2 from the router!
thanks again
86
