A little confused....need advice
I currently have a Cisco 2620 router which is connected to our Internet provider via point-to-point Frame Relay and a PVC.
I have 12 Public IP addresses available to me.
What I would like to do:
Add a Microsoft ISA server behind the Cisco 2620 router.
What is the best thing to do ?
My idea is to remove the NAT on the Cisco router and give the external NIC on the ISA server a Public IP address, then have NAT on the ISA server only.
Here is my current Cisco 2620 configuration of which I did not configure (I've added letters where the numbers should be in IP addresses for anonymity).
interface Loopback0
no ip address
no ip directed-broadcast
interface FastEthernet0/0
description connected to Internal LAN
ip address 10.0.0.9 255.0.0.0
ip access-group 100 in
ip nat inside
ip inspect FastEthernet_0_0 in
ip route-cache flow
interface Serial0/0
no ip address
encapsulation frame-relay IETF
ip route-cache flow
no ip mroute-cache
frame-relay lmi-type ansi
interface Serial0/0.51 point-to-point
description connected to Internet
ip address a.b.c.d 255.255.255.252
ip access-group 101 in
ip nat outside
ip inspect Serial_0_0_51 in
frame-relay interface-dlci 51 IETF
router rip
version 2
passive-interface Serial0/0.51
network 10.0.0.0
no auto-summary
ip nat pool NATPOOL1 a.b.f.g a.b.f.g+4 netmask 255.255.255.0
ip nat inside source list 1 pool NATPOOL1 overload
: <- these mean "...and so on...."
access-list 1 permit 10.0.0.0 0.255.255.255
access-list 100 permit ip any any
access-list 101 deny tcp host a.b.f.g-7 eq www any
If what I proposed earlier is the way to go, how would I go about doing all this?
To Remove the NAT, what do I do?
After removal, will this allow the public IP addresses to pass? What else would be neede to do so.
I've looked at a few example scripts but am a little confused about how to do all this.
If it doesn't make any sense, please request more info. Any advice is much appreciated.
Be gentle, I haven't had too much experience and don't want to screw things up.
Mark.
1 REPLY
Re: A little confused....need advice
Hi Mark:
Before going to far, what is the reason you are thinking about doing it the way you mentioned? I ask, because in NAT you can do a one-to-one relationship.
IP nat inside source static
This would allow outside users to access the server internally.
Thanks...Steve
74
