A NAT Destination Case
I need a nat config to alter destination address of packets coming in form the inside, traveling to the outside. Will "ip nat inside destination" command do this? As long as I know there's no "ip nat outside destination" command.
Best regards.
1 REPLY
Community Member
Re: A NAT Destination Case
Hi Kivanc,
Good Day! :-)
Please see below my response to your queries.
I once saw this command in a 7206 which has the ip nat outside destination command, and the IOS version is 12.2(6) with a 3DES feature set. The command "ip nat outside destination static" is a hidden and unsupported command. In this case you need to use ip nat outside source static or ip nat inside source static.
Also, I found a Bug ID that affects this command:
CSCdv23427 Bug Details
Headline: Preventing incorrect inside destination static/outside dest cmds
Product: all
Component: NAT
Severity: 3
Status: Resolved
First Found-in Version: 12.1, 12.2
First Fixed-in Version: 12.2(12.5), 12.2(12.5)S, 12.2(12.5)T, 12.1(17.1), 12.2(13.3)B, 12.1(18.1)E,
12.2(15)BW, 12.2(15)BZ, 12.2(15)BX, 12.2(15)ZN Version help
Release Notes:
Blocking of "ip nat inside destination static" & "ip nat outside destination" commands to go
through.
These are the other options that you can use:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123tcr/123tip1r/ip1_i2gt.htm#1079462
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123tcr/123tip1r/ip1_i2gt.htm#1079180
I hope the above information helps. ;-)
Best Regards,
Ansley R. Verzosa
143
