a problem with HSRP
Hi:
I just meet a problem that seems very strange.I config HSRP on two router as follow:
R1:
interface FastEthernet0/0.10
encapsulation dot1Q 120
ip address 26.176.63.91 255.255.255.0
no ip redirects
standby 120 ip 26.176.63.98
standby 120 timers 10 40
standby 120 priority 150
standby 120 preempt
R2:
interface FastEthernet0/1.10
ip address 26.176.63.92 255.255.255.0
no ip redirects
ip policy route-map setprecedence
standby 120 priority 120
my problem is : one pc in the same VLAN use the default gateway 26.176.63.98 ,but the pc can not ping the 26.176.63.98 .On both router ,I check the HSRP status and the status are normal . when the pc change the gateway ,for example 26.176.63.92 ,the pc can ping the gateway .
so i clear the configuration on R1 and reconfig the R1 as before ,the pc can ping the 26.176.63.98 (default gateway).
why ? can you tell me how to troublshoot ?
1 REPLY
Re: a problem with HSRP
Here is a detailed troubleshooting document if this is a Catalyst switch environment.
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094afd.shtml
And here are all the other HSRP tech-tips:
http://www.cisco.com/en/US/tech/tk648/tk362/tk321/tech_protocol_home.html
99
