Community Member
A problem with Switch HP 5500 EI
hi everybody,
I have a problem with SW HP 5500 EI J377A. I format flash of switch. After reset, the switch can't run normal, it has norfitication as: "No correct default file to boot!", and boot menu as attach picture
I've search, but i can't have a solution to troubleshoot this problem
Can you help me please, thanks alot.
Re: A problem with Switch HP 5500 EI
I think you'll be better off in a HP forum or HP support.
http://h30499.www3.hp.com/t5/Comware-Based/A5120-No-correct-default-file-to-boot/td-p/6032539#.UkvVanLm7fI
Rolf
Purple
You formatted flash so you deleted the OS so it can't boot anymore, you'll have to install a valid OS but you'll surely find the answer of how to do on a specific HP forum like Rolf told you.
Alain
1177
