A strange problem with 2950
zywvip
Hi, everyone.
I am experiencing a strange problem with
2950.
The IOS of the Switch is c2950-i6q4l2-mz.121-19.EA1c. Whenever I plug out a cable or one of the pcs turns up,all active access ports of the switch turn Amber and lose connectivity about 20 seconds. The problem was solved after I upgrade the IOS to 12.1(22).
Can anyone give me an explaination of this problem or detailed bug information ?
lgijssel
Level 9
Level 9
You were probably running rapid spanning tree?
This was an issue with 12.1(19)EA1c.
Bug IDs CSCee39647 & CSCee73256
Leo
Thank you very much
This is the information I need.
