A wireless backup for an ADSL connections
ahmed1148
Hello!
I have an 871 at a remote site. Connection is via ADSL. The link is split into 2 tunnels, 1 Tunnel is for direct internet breakout and the other is to come accross over the WAN into my network for non-internet requests.
I want to setup IBURST to be used as a backup in case the ADSL link drops.
How do I go about doing this?
I am gone grey looking for documents that can guide me.
I have attatced a sample config for more information on my current setup.
Any assistance would be GREATLY APPRECIATED!
paolo bevilacqua
If ibusrt connects via ethernet, to make it work on the 871, you need to download advanced ip services for your router. This will let you configure vlans for the 4 ports, one of them you will use to connect to wireless. After that you can use initially floating static for the backup.
