AAA for a CAT6500 running CatOS.
I have currently installed a few Catalyst 6509's, with MSFC's the works. My AAA does not seem to work. From the MSFC's the AAA works fine but from the CAT6509 SUP-Modules I am experiencing problems. I can ping the ACS server but fail to authenticate. Between the switches and the ACS is a firewall. For now the rules are pretty open. AT the end of the day it should work if I can ping the ACS. Any idea's? Does it use a different port number than what the IOS based products?
1 REPLY
Bronze
Re: AAA for a CAT6500 running CatOS.
Uses the same port, and unless you have an access list of some kind there is no reason you shouldn’t be fine as long as you can ping each other.
114
