Community Member
About Catalyst 2980G problem?
FL4-CBDL-2980G> 2003 Dec 18 10:28:30 %SYS-3-2_ERROR: 1/Enhanced Port Security notification mechanismfailed
What is problem
VIP Purple
Re: About Catalyst 2980G problem?
I think this error is SNMP (trap) related. Do you get this error frequently or did it just come up once ? Can you post the switch configuration ?
Georg
Community Member
FL4-CBDL-2980G> 2003 Dec 18 10:28:30 %SYS-3-P2_ERROR: 1/Enhanced Port Security n
otification mechanism failed
2003 Dec 18 10:28:33 %SYS-3-P2_ERROR: 1/Enhanced Port Security notification mech
anism failed
2003 Dec 18 10:28:51 %SYS-3-P2_ERROR: 1/Enhanced Port Security notification mech
anism failed
2003 Dec 18 10:28:54 %SYS-3-P2_ERROR: 1/Enhanced Port Security notification mech
anism failed
2003 Dec 18 10:28:58 %SYS-3-P2_ERROR: 1/Enhanced Port Security notification mech
anism failed
2003 Dec 18 10:29:01 %SYS-3-P2_ERROR: 1/Enhanced Port Security notification mech
anism failed
2003 Dec 18 10:29:04 %SYS-3-P2_ERROR: 1/Enhanced Port Security notification mech
anism failed
2003 Dec 18 10:29:07 %SYS-3-P2_ERROR: 1/Enhanced Port Security notification mech
anism failed
2003 Dec 18 10:29:10 %SYS-3-P2_ERROR: 1/Enhanced Port Security notification mech
anism failed
2003 Dec 18 10:29:13 %SYS-3-P2_ERROR: 1/Enhanced Port Security notification mech
anism failed
2003 Dec 18 10:29:16 %SYS-3-P2_ERROR: 1/Enhanced Port Security notification mech
anism failed
2003 Dec 18 10:29:19 %SYS-3-P2_ERROR: 1/Enhanced Port Security notification mech
anism failed
FL4-CBDL-2980G> (enable) 2003 Dec 18 10:30:29 %SYS-3-P2_ERROR: 1/Enhanced Port S
ecurity notification mechanism failed
sh 2003 Dec 18 10:30:32 %SYS-3-P2_ERROR: 1/Enhanced Port Security notification m
echanism failed
log
Network Management Processor (ACTIVE NMP) Log:
Reset count: 51
Re-boot History: Nov 30 2003 16:04:45 0, Nov 23 2003 16:48:39 0
Nov 07 2003 15:19:57 0, Oct 12 2003 11:27:15 0
Sep 30 2003 09:44:52 0, Sep 26 2003 13:31:20 0
Sep 21 2003 16:48:23 0, Sep 08 2003 10:49:51 0
Sep 07 2003 13:09:16 0, Sep 05 2003 15:42:54 0
Bootrom Checksum Failures: 0 UART Failures: 0
Flash Checksum Failures: 0 Flash Program Failures: 0
Power Supply 1 Failures: 0 Power Supply 2 Failures: 0
DRAM Failures: 0
Exceptions: 0
Last software reset by user: 4/25/2002,20:22:58
MCP Exceptions/Hang: 0
Heap Memory Log:
Corrupted Block = none
01. 1/1/2000,22:40:342003 Dec 18 10:30:50 %SYS-3-P2_ERROR: 1/Enhanced Port Secur
: convertCiscoMIB:PreSac(0) checksum failed: 0x0(0x4C5C)
Module 2 Log:
Reset Count: 52
Reset History: Sun Nov 30 2003, 16:04:50
Sun Nov 23 2003, 16:48:44
Fri Nov 7 2003, 15:20:02
Sun Oct 12 2003, 11:27:20
Module 3 Log:
Reset Count: 52
FL4-CBDL-2980G> (enable) 2003 Dec 18 10:30:53 %SYS-3-P2_ERROR: 1/Enhanced Port S
2003 Dec 18 10:30:56 %SYS-3-P2_ERROR: 1/Enhanced Port Security notification mech
anism failed
2003 Dec 18 10:30:59 %SYS-3-P2_ERROR: 1/Enhanced Port Security notification mech
anism failed
2003 Dec 18 10:31:02 %SYS-3-P2_ERROR: 1/Enhanced Port Security notification mech
anism failed
2003 Dec 18 10:31:05 %SYS-3-P2_ERROR: 1/Enhanced Port Security notification mech
anism failed
2003 Dec 18 10:31:08 %SYS-3-P2_ERROR: 1/Enhanced Port Security notification mech
anism failed
VIP Purple
which OS version are you running ? Might be a software bug...if you post the version I will run it through the bug toolkit (provided that you have not done that yet)...
Georg
134
