Acceptable level of CRC errors on frame relay WAN links?
I've noticed quite a disparity from one WAN router to another on our network as it relates to CRC errors. However, I have no frame of reference as to what is acceptable. My gut instinct tells me that "786965" is not a good thing (see log information below for details). Any insights on this matter in terms of assessing CRCs would be greatly appreciated. Thanks!
3542 CRC
786965 CRC
1064 CRC
EXAMPLE 1
Serial0/0 is up, line protocol is up
Hardware is PQUICC with Fractional T1 CSU/DSU
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
reliability 255/255, txload 1/255, rxload 13/255
Encapsulation FRAME-RELAY IETF, loopback not set
Keepalive set (10 sec)
LMI enq sent 845576, LMI stat recvd 845566, LMI upd recvd 0, DTE LMI up
LMI enq recvd 0, LMI stat sent 0, LMI upd sent 0
LMI DLCI 1023 LMI type is CISCO frame relay DTE
Broadcast queue 0/64, broadcasts sent/dropped 1968353/0, interface broadcasts 1827420
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 13w6d
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 24
Queueing strategy: weighted fair
Output queue: 0/1000/64/24 (size/max total/threshold/drops)
Conversations 0/26/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1152 kilobits/sec
5 minute input rate 84000 bits/sec, 10 packets/sec
5 minute output rate 12000 bits/sec, 9 packets/sec
75253767 packets input, 2961814545 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
10748 input errors, 3542 CRC, 6015 frame, 0 overrun, 0 ignored, 1191 abort
66597348 packets output, 722048064 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
1 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
EXAMPLE 2
MTU 1500 bytes, BW 512 Kbit, DLY 20000 usec,
LMI enq sent 53000, LMI stat recvd 52931, LMI upd recvd 0, DTE LMI up
Broadcast queue 0/64, broadcasts sent/dropped 123253/0, interface broadcasts 114321
Last clearing of "show interface" counters 6d04h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 40
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/22/128 (active/max active/max total)
Available Bandwidth 384 kilobits/sec
5 minute input rate 28000 bits/sec, 7 packets/sec
5 minute output rate 3000 bits/sec, 7 packets/sec
1871783 packets input, 1078252500 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 50 giants, 0 throttles
1332972 input errors, 786965 CRC, 540869 frame, 0 overrun, 0 ignored, 5137 abort
1775834 packets output, 302835862 bytes, 0 underruns
0 output errors, 0 collisions, 132 interface resets
62 carrier transitions
EXAMPLE 3
reliability 255/255, txload 3/255, rxload 71/255
LMI enq sent 88215, LMI stat recvd 88215, LMI upd recvd 0, DTE LMI up
Broadcast queue 0/64, broadcasts sent/dropped 205316/0, interface broadcasts 190613
Last clearing of "show interface" counters 1w3d
Conversations 0/10/256 (active/max active/max total)
5 minute input rate 143000 bits/sec, 17 packets/sec
5 minute output rate 8000 bits/sec, 15 packets/sec
2185316 packets input, 1454400807 bytes, 0 no buffer
3039 input errors, 1064 CRC, 1354 frame, 0 overrun, 0 ignored, 621 abort
2022635 packets output, 362917779 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
  • Other Network Infrastructure Subjects
1 REPLY
Re: Acceptable level of CRC errors on frame relay WAN links?
A recommendation:
Any input error value for cyclic redundancy check (CRC) errors, framing errors, or aborts above one percent of the total interface traffic suggests some kind of link problem that should be isolated and repaired.
Tips:
http://www.cisco.com/univercd/cc/td/doc/cisintwk/itg_v1/tr1915.htm
574
