Community Member
Access control .Need expert advice..!
I have to design LAN as below:-
Three networks comming into local lan & requirement is that all usersof LAN will get limited access on all three network as needed.
1.192.168.10.0(private network lease line)
2.192.168.100.0(private network lease line)
3.2 mbps internet line.
4.192.168.1.0(Local area network.)
how i design the solution so that all LAN user can access all network with limited access restriction.
what type of devices i need like L-3 switch & firewall for internet.
I do not want use any router but L-3 switch would be ok with VLAN implementation. Please Guide me
Community Member
Re: Access control .Need expert advice..!
Check out the 3560 switch. It supports inter-vlan routing.
http://www.cisco.com/en/US/products/hw/switches/ps5528/products_data_sheet09186a00801f3d7d.html
- Iain
hi,,,
u can configure your layer 3 switch for intervlan routing...and u can also apply access control list...and intervlan routing is easy to configure and u will have more control on your network...from searching also u will get good documetation on it...
regards
Devang
107
