Webcast-Catalyst9k
Access problem to a Cisco 3500XL
What will happen with a switch if another node e.g. a printer gets the same IP address at VLAN1 on the switch?
That is what happened for me. Someone accidentally give a printer the same IP address as VLAN1 on one of two switches. Nobody noted it because the printer and the switch worked well, until one day I should Telnet the switch
Then I gave the printer another IP and cleared the DHCP address pool. But I still can’t telnet or ping the switch. Otherwise the switch works fine.
Via the command “show cdp neighbour detail” on the neighbour switch, I can verify that it is the correct IP address I try to connect to, and of course I’ve Telnetted the switch before.
Why can’t I get in contact with the switch? Nothing has changed on the switch.
Is it really necessary to reboot it?
TIA
Re: Access problem to a Cisco 3500XL
HI
can u try this
interface vlan 1
shut
no shut
Mahmood
Hi Mahmood
Maybe I could, but I don't have physical acces to the switch, unless I drive 200 KM :-(
I hoped that I could do something remote ;-)
On the router/layer3 switch at the site do a 'clear arp' and try getting to it?
Pls. rate the post if it helped.
HTH,
Sundar
Hi Sundar
Thanks for your suggestion. Unfortunately it didn’t help.
ALso try clearing the Redirects
Clear ip redirects
Try getting into the GUI rather than Telnet. Use a browser and go to the VLAN 1 IP address.
I've had similar issues and this seems to work.
Jim
Purple
Go to the router it is attached to then source your telnet from the directly attached interface and see if you can get to it that way , this will rule out a default gateway problem .
Tried that to - didn’t helped.
Had a similar problem once. Got someone to power the switch off/on, all cured. Drastic but.....
279
