Webcast-Catalyst9k
Accessing cisco wireless controller
Hi All
I have a cisco 5500 WLC that was decommissioned and is now going to be put back on the network.
I have the old IP of 10.1.2.210/24 which it was part of. I put my laptop  on the same network 10.1.2.10
I access the gui whilst connected to the SP on both http & https I cannot access the browser and I cannot ping the box.
When I plug it in to one of the ports that requires an SFP. I can then ping it but still cant access it via the gui.
Can anyone help ?
1 REPLY
How did you configure those
How did you configure those ports?  LAG any VLAN tagging or untagged?
You can try to connect a computer and the WLC to a switch first and then try accessing it.
77
