ACL dropping out of 3750 using Cisco Netwok Assistant
Has anybod else experienced the loss of ACL from a list that is updated on a Catalyst 3750 using Cisco Network Assistant V1.0(1a). Is there a later version? This has happened to us many times. We are not sure if it is some resource limit on the switch or if the Assistant software is the cause.
Any help would be great,
Gerry
1 REPLY
VIP Purple
Re: ACL dropping out of 3750 using Cisco Netwok Assistant
Hello Gerry,
I think they are up to version 3.0 now, check this link:
http://www.cisco.com/en/US/products/ps5931/
Which IOS version are you using on your 3750, and which access list related command are you trying to configure ? Depending on the IOS, certain commands are not supported...
GP
109
