ACL using FQDN?
I wish to create an ACL using the fully qualified domain name instead of IP addresses.
The problem is that my ACL will resolve only the first IP address but not the rest.
I have been using the Windows update website as my test.
When I sniffed the process, I was able to pull out five different FQDNs.
v4.windowsupdate.microsoft.com
v4-ori.windowsupdate.microsoft.com
wu-ori.microsoft.com
origin2.microsoft.com
Those names resolve to at least 27 IP addresses. Ug!
I was able to write the ACL using those 27 IPs and make it work but there is no guarantee that the IPs won't change in the future.
Anyone have any ideas? Thanks!
1 REPLY
Bronze
Re: ACL using FQDN?
I think you can use NBAR to filter all traffic going to a particular website using the "match protocol http" class map option.
I'm not sure if your router can support NBAR so use the Cisco.com Feature Navigator to verify that.
Here is an Example of how to filter out all web
requests to any microsoft.com website.
Router(config)#class-map match-any block_ms_com
Router(config-cmap)#match protocol http host "*microsoft.com*"
Router(config)#policy-map block_ms_com
Router(config-pmap)#class block_ms_com
Router(config-pmap)#set ip dscp 1
Router(config)#interface eth 0/0
Router(config-if)# description inside network
Router(config-if)#service-policy input block_ms_com
Router(config)#access-list 105 deny ip any any dscp 1
Router(config)#access-list 105 permit ip any any
Router(config)#interface serial 0/1
Router(config-if)# description connection to ISP
Router(config-if)#ip access-group 105 out
Reference:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt1/qcfnbar.htm
1383
