Webcast-Catalyst9k
ACLM opens scenario read-only
We use ACLM version 1.3.
The problem is - if scenario is created by one user (with Global Scenario option) the second user can open it only in read-only mode ?
Re: ACLM opens scenario read-only
We just discovered that this is a feature of ACL Manager - if one user creates global scenario then another CiscoWorks user can only view the scenario in read-only ! This almost means that one ACL on a specific router can be modified only by one user !?
Of course this is not the case in a real life where there are at least two administrators for the same router, how do others solve this ? We consider building the same scenarios for all the users, is this the right solution ? Any better solution ?
This is a feature in Aclm 1.3 which has been changed in Aclm 1.4.
~preetham
97
