05-15-2003 07:42 PM - edited 03-02-2019 07:23 AM
In the Process Status, AclmServer is allways "Running but busy flag set ",and it can not work, what's the matter of it?
thanks firstly.
05-15-2003 08:14 PM
These are some of the states of the AclmServer process
"Administrator has shut down this server": implies AclmServer is not running
"Program started - No mgt msgs received": implies AclmServer is in the process of coming up
"Running but busy flag set ": implies that AclmServer is up and running (one can safely ignore the part "busy flag set"). All functionalities of ACLM like "Edit ACLs", "Edit Templates", etc will now be available.
In your case, AclmServer is in the running state and so you should be able to access the AclmServer via "Edit Acls", "Edit Templates", etc. Do let us know if you are facing any problem.
Meanwhile, can you please let us know the version of AclManager.
Rajesh
05-15-2003 08:30 PM
The problem is that I can not access the AclmServer via "Edit Acls", "Edit Templates", etc.
I have reinstall the CD1 and RME and ACL again, the problem is still there.
05-15-2003 09:40 PM
Hi Chu,
Can you please forward your mail to cs-aclm@cisco.com with the following info (you get a wider audience here)
- any messages/errors when clicking on "Edit ACLs" like "Failed to connect to AclmServer"
- any messages in aclm.log present under
- any messages in the Java console
- versions of AclManager, RME
Rajesh
05-15-2003 10:09 PM
# pwd
/opt/CSCOpx/objects/aclm
# ls -l
total 16
-rw-r----- 1 casuser casusers 207 May 16 11:33 aclm.log
-rw-r----- 1 casuser casusers 256 May 16 11:29 aclm.log1
drwxr-xr-x 2 casuser casusers 512 May 16 10:38 bin
drwxr-xr-x 3 casuser casusers 512 May 16 10:38 com
drwxr-xr-x 7 casuser casusers 512 May 16 10:40 data
drwxr-xr-x 3 casuser casusers 512 May 16 10:38 etc
drwxr-xr-x 2 casuser casusers 512 May 16 10:38 jarfiles
drwxr-xr-x 2 casuser casusers 512 May 16 10:38 patch
# more aclm.log1
Informational: AclmServer starting Cisco Process Manager communication thread
EnableFirewall property is set to use firewall in aclm.properties.
Initializing ACLM server...
Initializing ACLM server...done.
ShutDown requested from the Cisco Process Manager
# more aclm.log
software version:
ACL Manager 1.4
Resource Manager Essentials 3.4
when clicking on "Edit ACLs, it seemed that something are running but there is nothing on the
screen will occure.
when clicking on RME->Administration->ACL Management->Edit ACL Templates, it is "Running
Template Manager..."
Select Resource Manager Essentials > Administration > Job Approval > Edit Preferences, at the
ACL Manager tab, there is a "Unable to connect to ACLM server".
05-15-2003 10:33 PM
Can you tell us the browser versions? Are you observing similar symtoms on both IE and netscape?
It will be great if you can direct your messages to cs-aclm@cisco.com
Rajesh
05-15-2003 10:46 PM
Yes, I observed similar symtoms on both IE and netscape. IE version:6.0 netscape version:4.76
I have sent a mail to cs-aclm@cisco.com
Does it matter that the NMS server was access from browser through NAT, means that NMS server's IP is 10.*.*.*, map to a IP 211.*.*.* ?
thanks
05-15-2003 11:02 PM
ACLM does not work over NAT. This is because CORBA does not work under such circumstances.
~oreetham
05-16-2003 12:06 AM
It seemed that NAT is not the reason.
When just reboot the server, nothing has been done, I can see the status of aclm is busy yet.
thanks
05-16-2003 01:02 AM
"ACLM does not work over NAT" implies that the CLIENT cannot connect to AclmServer. That is why you are not able to see any activity after asserting
"Edit ACLs" or "Edit Templates". Nevertheless, the AclmServer appears to be working fine which is rightly indicated by "Running but Busy flag set" (you can ignore the "busy" mentioned in the message) and the log messages.
Rajesh
