Active and Standby problem with SUP IV engines in 4507
I have a 4507R wtih two SUP IV engines,when there is a cold restart,the engine in slot 2 always be the active ,i have exchange the two engines in slot 1 and 2,but engine in slot 2 still to be active after a cold restart,eager for your help!
  • Other Network Infrastructure Subjects
1 REPLY
Re: Active and Standby problem with SUP IV engines in 4507
This is normal behavior due to the algorithm used to elect the active supervisor.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_1_20/config/rpr.htm#1100301
"When the switch is powered on, the two supervisor engines determine which will serve
as the primary and which will be the standby. Usually, the supervisor engine that boots first,
either in slot 1 or 2, becomes the active supervisor engine."
The following algorithm is used to decide which Supervisor is active:
1. If only one Supervisor in slot 1 is installed, then it's active.
2. If Supervisor-slot 2 has declared itself active after switchover, then the Supervisor in slot 1
becomes standby until the next reload or until Supervisor in slot 2 is reset or power is cycled.
3. If Supervisor-slot 2 hasn't declared itself active, then the Supervisor-1 is active after passing
POST diagnostics test.
214
