Community Member
Actual Bandwidth on Serial Frame Relay links
Can someone tell me how I can tell the actual bandwidth available on my Serial interface and its sub-interfaces.
I think my ISP is over-charging me.
1 REPLY
Bronze
Re: Actual Bandwidth on Serial Frame Relay links
You may be able to determine the CIR via 'debug frame-relay lmi', but you may have to be using Cisco LMI for this (not sure if other LMI types show CIR). But the only way to determine the actual bandwidth available is to run a bandwidth testing application like TTCP.
360
