Community Member
Add New Device Problem
Administration > Inventory > add device >
The router 1721 is not recognized by ciscoworks because I have a old version RME 3.2
I have download the package Rtr1700.cv50.v6-0.zip and StackMaker.cv50.v1-1.zip for ciscoview But for RME the problem still persists
Thank you for your collaboration
Blue
Re: Add New Device Problem
The package that you downloaded (Rtr1700.cv50.v6-0.zip and StackMaker.cv50.v1-1.zip) is for CiscoView only and does not apply to RME or any other application within CW2000. Note that all the applications within the CW2000 bundle are separate and adding a device package to one will not affect the functionality of the other application like in this case. The device package in this case will only provide support for that particular device for CiscoView.
Now, you're running RME 3.2, which does not support 1721 router. Only RME 3.4 supports it according to: http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000e/e_3_x/3_4/dev_sup/e3_4.htm
Community Member
Thank's
212
