Adding a 3548XL switch to environment running MST Protocol
I have a LAN environment where the spanning-tree mode is MST. This LAN is made of Cisco 6509's and Cisco 4506's - where the design is fully redundant .
I now need to add a Cisco 3548XL to this topology, and this is where the issue arises since the 3548 does not understand MST, and as such I don't want to create any STP issues.
What is the best way to go about implementing this?
Should I create a separate VTP domain and have a trunk connection to the existing LAN?
OR
Should I place it on the same VTP domain and a regular trunk connection?
OR
Should it be a separate LAN, i.e. a routed connection to existing LAN?
OR ?????
Please, any ideas with Pro's and Con's would be very helpful.
Thank you
Pradeep
Silver
Re: Adding a 3548XL switch to environment running MST Protocol
You can use PVST+ which can communicate with MST. But please note that, the PVST+ connection from 3548xl switch to the MST region MUST be through 802.1q trunks. Through tunneling concept, PVST+ and MST are interoperable.
Thank you for the feedback. I found out that the only drawback to introducing a PVST+ switch is an increase in the convergence time. I was able to mitigate this by disabling STP on the Cat3548xl, since it did not have any redundant links to the rest of the network.
302
