Adding a ATM 1A-E3 Module and configurig
I have just installed the above module into a 3640. I have uploaded IOS 12.2 but i am unable to us the controller command to add the atm controller. What command do i need to use to add the controller?
Bronze
Re: Adding a ATM 1A-E3 Module and configurig
If you are using the NM-1A-E3 module, then the interface will show up as interface atm x/y, not as a controller. Also, make sure the IOS feature set is PLUS to recognize the NM
With that module, you do not have to configure a controller. You should configure the ATM interface directly. Here is a link showing a sample configuration for PVCs:
http://www.cisco.com/warp/customer/121/routed_LLC.html
Also, make sure you have an IOS including the PLUS feature set. In other words, the filename should contain a 's' such as: c3640-is-mz.122-10a.bin
114
