Admin Up/Down port using SNMP
Can anyone advise how to shutdown and no shutdown a port on a cisco switch using just SNMP?
I can't find much documentation on it.
Cheers,
Ben
lgijssel
Level 9
Level 9
You can use the standard MIB2 for this: http://www.alvestrand.no/objectid/1.3.6.1.2.1.html
and then check the options under "SNMP MIB-2 Interfaces" The IfStatus is somewhere in there.
Then, find an application that allows you to do snmp set instructions, such as SNMPchttp://www.castlerock.com/
and assign a write community string to your devices. After doing all this, it should work!
regards,
Leo
lgijssel
Level 9
Level 9
regards,
Leo
Thanks - the exact MIB is:
IF-MIB::ifAdminStatus
snmpset syntax is:
Interface UP:
snmpset -v1 -c community hostname IF-MIB::ifAdminStatus.interface i 1
Interface DOWN:
snmpset -v1 -c community hostname IF-MIB::ifAdminStatus.interface i 2
Hope this helps anyone else trying to do the same.
Cheers,
Ben
