ADSL, Cable Broadband and NAT with 1760 - Configuration Help Please
I'm new to Cisco routers and trying to setup a 1760 to load balance between two ISPs, one through a WIC-1ADSL and the other through a WIC-1ENET.
Both have a single IP address which I need to NAT overload through.
I have spent probably the best part of 2-3 days wading my way through the forums and the reams of Cisco documentation and configuration examples but I can't find an example of this setup. I can get the Broadband OR the ADSL to work but I seem to be coming unstuck on how to NAT BOTH the interfaces. The closest forum thread I found was http://forum.cisco.com/eforum/servlet/NetProf;jsessionid=b5e3x1agv1.SJ2A?page=netprof&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.ee943ac but unforunately nobody answered his question.
Can anybody point me in the right direction? Or post there own working configuration? That would give me enough to get me sorted. I don't need anything fancy, I'm not concerned about about making internal resources available over both interfaces apart from a mail server which I can sort out by having two MX records.
Thanks, Jason
Re: ADSL, Cable Broadband and NAT with 1760 - Configuration Help
Hi Jason
Scott as you know is away at the moment but i'm sure i can set you in the right direction. This can definitely be done, however we ourselves have stumble across some issues with the load-balancing on a per destination basis over ATM interfaces. But that would be far too much to go into.
What you basically need to do is setup 2 dialer interfaces and map them to your respective ADSL and ethernet interfaces. You then create 2 ip nat pools for each ISP that you have connections with to the internet.
In terms of load balancing this will be done with configuring you routes, create 2 wild card routes with next hops of the dialer interfaces.eg ip route 0.0.0.0 0.0.0.0 ?
The next thing is to specify which traffic you want Natted out to your 2 links. To do this you create 2 route-maps that match any traffic destined for the dialer interfaces eg. route-map test permit 10
match interface dialer ?
Once this done you have only to configure the nat statements that nat the route-maps to your nat pools that you have already created.
I hope have set you in the right direction.
Kieran Kelly
Kieran,
Thanks for the pointers, they are much apprecitated.
I have manged to get so far but am stuck on one point. What I am trying to achieve is load balancing over the two connections. I believe I do not need to go as far as BGP as I only want to load balance out (the only important incoming connection is SMTP and i can just set up two MX records to cover either connection).
So far I hve got the following configuration:
version 12.3
hostname Router
enable secret 5 xxxxxx
enable password xxxxxx
ip subnet-zero
ip cef
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
hold-queue 224 in
interface Ethernet0
ip address dhcp
ip nat outside
full-duplex
no cdp enable
interface FastEthernet0
ip address x.x.x.x 255.255.255.0
ip nat inside
speed auto
full-duplex
no cdp enable
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname xxxxxxxxxxxxxxxxxx
ppp chap password 0 xxxxxxxxxx
ip nat inside source route-map map-1 interface Dialer1 overload
ip nat inside source route-map map-2 interface Ethernet0 overload
ip nat inside source static tcp y.y.y.y 25 x.x.x.x 25 extendable
! There is an MX record that points to the IP for Dialer1 and should be routed to the internal server at y.y.y.y
ip nat inside source static tcp y.y.y.y 80 x.x.x.x 80 extendable
! There is a WWW record that points to the IP for Dialer1 and should be routed to the internal server at y.y.y.y
ip nat inside source static tcp y.y.y.y 53 x.x.x.x 53 extendable
! The DNS server at y.y.y.y should be able to answer queries from outside - THIS DOESNT WORK
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Ethernet0
no ip http server
dialer-list 1 protocol ip permit
no cdp run
route-map map-1 permit 10
match interface Dialer1
route-map map-2 permit 10
match interface Ethernet0
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password xxxxxx
login
end
This works "a bit" but there is clearly something wrong. Trying to browse the web brings up pages extremely slowly (and sometimes not at all). Clearly the routing isn't working as intended but I don't know where I've gone wrong - or can I not achieve what I am trying to?
Also, the "ip nat inside source static tcp 10.10.10.1 53 x.x.x.x 53 extendable" doesn't achieve what I want it to either. I need to make my internal DNS server publicly available as it holds the records for a public domain name. I thought this was the correct syntax but I must be missing something as it doen't work. I know it is my router config because if I put my old router back it works fine.
Any suggestions will be much appreciated.
Regards, Jason
Well I still don't know why my load balancing doesn't work but I solved my internal DNS problem so I thought I would post the solution in case anybody else stumbles across this in the future.
Apart from the fact that DNS queries are UDP rather than TCP, (duh - must have had my Homer head on that day), I needed to use the no-payload option. I presume this is to do with the way that the hosting company is redirecting the DNS requests to my DNS server. Anyway it works now:
ip nat inside source static udp 10.10.10.1 53 x.x.x.x 53 extendable no-payload
Still no joy with the load balancing though - any suggestions?
Thanks, Jason
172
