adsl failover to ISDN
My primary line is running on ADSL and will failover to ISDN with config below but unfortnately inorder to get every ws to access internet,we need to removed IP NAT source list 1 interface dialer1 inorder to get it run but once removed the ADSL connection will not work again.Any advise.
Building configuration...
Current configuration : 1930 bytes
version 12.3
service password-encryption
hostname Router1721
enable secret xxxxx
no aaa new-model
ip subnet-zero
isdn switch-type basic-net3
interface ATM0
--More-- no ip address
backup delay 1 1
backup interface Dialer2
no atm ilmi-keepalive
pvc 0/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
hold-queue 224 in
interface BRI0
no ip address
ip nat outside
encapsulation ppp
dialer rotary-group 2
dialer-group 2
interface FastEthernet0
ip address 192.168.186.223 255.255.255.0
ip nat inside
speed auto
--More-- !
interface Dialer1
description Connection to ADSL
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp chap hostname xxxx
ppp chap password xxxx
ppp pap sent-username xxxpassword xxxx!
interface Dialer2
description Backup ISDN
ip nat outside
encapsulation ppp
no ip split-horizon
dialer in-band
dialer idle-timeout 300
dialer string 1525
dialer hold-queue 10
--More-- dialer-group 2
ppp authentication chap pap callin
ppp chap hostname assbpg
ppp chap password xxxxx
ppp pap sent-username xxxx password xxxxxxxxxxxx ppp multilink
router rip
network 192.168.186.0
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source list 2 interface Dialer2 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Dialer2
no ip http server
access-list 1 permit 192.168.186.0 0.0.0.255
access-list 2 permit 192.168.186.0 0.0.0.255
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
line con 0
--More-- line aux 0
line vty 0 4
password xxxx
login
no scheduler allocate
end
  • Other Network Infrastructure Subjects
Re: adsl failover to ISDN
Looks like you are using dialer 1 as the primary interface, but the backup interface command is on the ATM physical interface itself.
Can you try putting the "backup interface" command on dialer 1 istead?
just done some checking.. you can't actually issue "backp interface" on the dialer... is it possible to use the physical interface instead of dialer 1 for the adsl?
try it by setting this config on dialer1.By exchanging ADSL as the primary line and my ISDN as backup line.
backup delay 1 1
backup interface dialer2
Any advise.
76
