Community Member
ADSL/FRAME/ISDN Routing
We are looking into the idea of dropping our Frame-relay links and getting our small sites to use ADSL, with a backup of ISDN. What is the best way to configure the cisco routers?
1603 router is connected to a lan, ISDN, and at moment frame. if I put a firewall (non cisco) on the lan and connect this to an ADSL router (the firewall will talk to our main sites firewall and create a VPN tunnel-this I can do). The workstations will have a default route of the 1600 so how do I tell the cisco if the ADSL link is down, use the ISDN link? Is it a case of creating multiple ip route statements but putting a higher cost of the ISDN backup link, is there a better way or will this not work?
1 REPLY
Silver
Re: ADSL/FRAME/ISDN Routing
Hi Hardy,
Best way is to configure an ISDN backup and configure to trigger it if the keep alives does not come upto some time limit ,
that is when primary goes down....
84
