rob
ADSL outbound Load balancing
Hi ,Im trying to load balance 2x2meg adsl lines that terminate in the same cisco 2610. Im using inbound balancing via OSPF as I also own the LNS(L2tp)routers. Currently for outbound connectivity from the 2610 ive put in 2 default routes . One via dialer 1 and the other via dialer 2
This sort of acheives load balancing except if I run mrtg I can see that one line gets used more than the other. Both lines are 256k upstream but i wondered if there was another method which may be more suitable
Re: ADSL outbound Load balancing
If you own both the routers, you could run ppp multilink.
rob
Hi,thanks for the quick reply
Im using dialer interfaces for each adsl connection
interface Dialer1
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname gotadsl.***/***-d**
ppp chap password 7 *******
ppp pap sent-username gotadsl.***/***-d** password ***
It wont allow me to put dialer interfaces into a multi link group.
Should I be using something other than a dialer interface perhaps!
117
