ADSL Router 1401 connection
Sometimes i have a problem with a router 1401 to access to Internet.
When Internet connection fails :
The ping to my router its ok, but i can't telnet the router.
To resolve the problem i shutdown the router and switch on then The internet connection and the telnet is OK
Thanks for your helps
1 REPLY
Re: ADSL Router 1401 connection
It’s probably running out of memory blocks. You should have your configuration gone thru by a Cisco tech.
111
