Webcast-Catalyst9k
Advanced Licensen for N7700
Hi all, I have purchased a pair of N7706, and I want to use the VDC feature on them, so I have also bought the N77-VDC1K9 license.
At the time I worked with the N7K series, when I want to restart or suspend a VDC from VDC1, I need a N7K-ADV1K9 be installed. Now, when moving to the N7706, I also want to have those features too. And, I suppose I need some kind of N77-ADV1K9 license, but there no such license!
So, my question is: Do I need a seperated license in order to use feature like suspending a VDC on N77 series (except the N77-VDC1K9 license)
Best regards,
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hi Tranviettu Yes, you should
Hi Tranviettu
Yes, you should be
Sandip
Hi TranviettuOn N77K, we have
Hi Tranviettu
On N77K, we have only N77-VDC1K9 license, with each N77-VDC1K9 license you can get 4 VDC
If you want 8 VDC with SUP2, you need 2 X N77-VDC1K9 license
Please let me know if you need further clarfication on this
Sandip
Thank you for your reply, so,
Thank you for your reply, so, with N77-VDC1K9 license, can I still use vdc suspend command?
Best regards,
Hi Tranviettu
Yes, you should be
Sandip
210
