Advice on catOS upgrade.....
I've got a 6513 switch running 6.3(5) at the moment. My new IDS-2 module requires 7.5(1) or higher. Since I don't see 7.5-anything listed on the Software Center, I'm guessing I'll go with the latest version of 7.6, however I find:
Current Version:
cat6000-sup2.6-3-5.bin
Prospective Version:
cat6000-sup2k8.7-6-5.bin
I can't find 7.6(5) without the "k8" feature. I'm just looking to perform an update to allow my IDS to function, I don't need any addn'l features right now. What can I do?
-alex
1 REPLY
Bronze
Re: Advice on catOS upgrade.....
Alex,
From the Software Download Technical Support page, you are looking at the correct CatOS image.
Catalyst 6000 Supervisor 2 Flash Code
I guess the filename shouldn't matter. You probably have done this but I would suggest to check the features and changes (in commands, for example) between 6.3 and 7.5. This might have an effect on your current setup/applications. I have seen quite a number of new commands added in version 7.x. And your first reference is the Release Notes, of course :-)
Goodluck!
106
