After power comes up, 3640 eth is not working
After a power outage, the eth port in our 3640 is not working. I just need to unplug and plug back in the net cable, and everything is ok.
It's not that eth0 is shutdown or else.
Is that a bug?
3640
C3640-IS-M), Version 12.0(4)T, RELEASE SOFTWARE (fc1)
2 T1 WIC cards
Elliott Bujan
1 REPLY
v.j
Re: After power comes up, 3640 eth is not working
It could be becoz the the other end may be having incompatible in negotiating duplex,speed...set them as per the other end.Or Check whether the keep alive is set to zero.
106
