Aggregating T1's using MLPPP
Can we aggregate multiple T1's and make it look like one big pipe using Multilink PPP? I know we can do this on 7500 routers with VIP's. If we were to do this on a 2600, is it possible? I went into T1 interface config mode using the controller T1 command and found nothing for multilink PPP.
If this can be done, what kind of T1 interfaces need to be used?
Kishen.
Re: Aggregating T1's using MLPPP
YES..You can use nxT1 or nxE1 link to get aggregated thruput. Here is the link which discuss that
http://www.cisco.com/warp/public/cc/pd/ifaa/pa/much/tech/althb_wp.htm
Now "ppp multilink" is interface command so you need to enter it under interface..For configuration (same for T1 links too)
http://www.cisco.com/warp/public/793/access_dial/ppp_11044.html
Also
http://www.cisco.com/univercd/cc/td/doc/product/aggr/10000/10ksw/mlppos.htm
What is the best method for balancing VoIP traffic over NxE1 links? Actually I use cef for balancig NxE1 links because I need run mpls on the router. Some link which discuss this issue ?
325
