Allow hotmail and yahoo and block other http traffic
m.athif
Since we do not have an URL filtering device, we intend to do this on a cisco 1721 router.
We need to allow only hotmail.com and yahoo.com and block other http traffic entering this router. Interface E0 is the input interface and F0 is the output interface connected to the internet. We also have implemented NAT on this router.
The problem is all the http traffic is getting blocked including hotmail and yahoo . Please let me know where am I going wrong , the configuration is attached.
videocon#sh run
Building configuration...
Current configuration : 1355 bytes
version 12.2
hostname videocon
logging queue-limit 100
enable secret ******
enable password ****
ip subnet-zero
ip name-server 202.x.x.5
ip cef
ip multicast-routing
class-map match-any permit
match protocol http host "hotmail*"
match protocol http host "yahoo*"
match protocol http host "msn*"
class-map match-any block
match protocol http host "*"
policy-map deny-unwanted-httptraffic
class permit
class block
police cir 1000000 bc 31250 be 31250
conform-action drop
exceed-action drop
violate-action drop
interface Ethernet0
ip address 192.168.1.24 255.255.255.0
ip nat inside
full-duplex
service policy-map input deny-unwanted-httptraffic
interface FastEthernet0
ip address 202.56.x.x.x.255.240
ip nat outside
speed auto
ip nat pool vdocon 203.145.x.x.x.162.104 netmask 255.255.255.0
ip nat inside source list 1 pool vdocon overload
ip classless
ip route 0.0.0.0 0.0.0.0 202.56.253.181
ip route 172.26.0.0 255.255.0.0 192.168.1.201
ip route 192.168.51.0 255.255.255.0 192.168.1.113
no ip http server
access-list 1 permit 172.26.0.0 0.0.255.255
line con 0
line aux 0
line vty 0 4
password ****
login
no scheduler allocate
end
tomanderin
you may want try using the match "not" syntax when setting up the class maps
not tested but poss something like
class-map match-any PERMIT-URL
match protocol http host "*yahoo*"
match protocol http host "*hotmail*"
class-map match-all DENY-URL
match protocol http host "**"
class-map match-all URL-TRAFFIC
match not class-map PERMIT-URL
match class-map DENY-URL
10 Replies 10
keith.campbell
you have your police statement set to drop all traffic.... conforming to the limits, exceeding the limits and violating the limits.
If you set the confirm action to transmit instead of drop you may see some traffic. Also, should this not be on your outside interface rather than your inside interface (stop the traffic as close to the source as possible) ?
best of luck !
If we make the confirm action to transmit then whole traffic will pass through. As I mentioned we need to allow only hotmail and yahoo and block other http traffic.
As you can see in the configuration we have police statement on "class block" so that the other traffic apart from hotmail and yahoo gets blocked.
I tried your suggestion but does not help. Please let me know if you have any other idea.
How about ;
policy-map mark-inbound-http
class permit
set ip dscp 1
interface FastEther0
service policy input mark-inbound-http
access-list 101 permit ip any any dscp 1 log
! Apply it outbound on the 'inside' interface where the target web servers are.
interface Ehernet0
ip access-group 101 out
I will give it a try in the lab.
Keith
Dear Keith,
Thanks for your prompt reply and suggestion. I tried your new configuration but it is still not working, whole traffic is getting blocked. I could see that there are no matches to access-list 101 for dscp 1, where as there were matches for the deny statement.
access-list 101 deny ip any any log ( 238 )
Infact I tried this configuration earlier but it did not work, hence i tried the other option of police statement but no luck. Can you please try this scenario in the lab and let me know your feedback.
Thanks in advance
Athif
Sorry Athif,
I have not had a chance to put it into the lab and will not get a chance until Sunday or Monday.
Sounds as if you have been through this already, but you could try using a different tagging method rather than dcsp to see if that works.... that's what I will do when I get the chance.
best of luck,
Keith
Can anyone help me on this ?
rabeder
hi,
try to configure "ip nbar protocol-discovery" on the ethernet where you want to match.
i had the same problem with matching rtp-traffic
Tried this, but still I am not able to see any matches on dscp 1 .
Just a thought, but would it help to put a leading * in the match like this:
match protocol http host "*msn*"
I tried
but still there are no matches, but I have seen an observation when I give the command " sh policy-map int e0" command I could see some matches for a day around 100 or so.. but I think it is only syn packets and not the traffic..but overall when I see the instantaneous status of the matches " sh access-list 101 " I do not see any match on dscp 1..some occassions 5 matches max. but the whole traffic is getting blocked.
tomanderin
It has worked , thanks a lot
