Amber LED --> Green LED...
Has anyone ever seen or can explain this...I am connecting a 2950 sw to a 2924 sw. The 2950 switchport is Green (up/up) while the 2924 switchport is Amber (down/down). I have tried different ports on the 2924 & 2950 w/the same results, have tried varying speed/duplex configurations, have also tried different xover cables, same issue. Configs are pretty generic...I have never seen an instance where one port is green while the port its connecting too is amber. I have also tried enable/disabling spanning-tree, didnt matter.
Thank you
Purple
Re: Amber LED --> Green LED...
Reboot the 2924 then look in the logs and see if it fails POST. sounds like the 2924 is failing at least part of the POST.
Its a production switch, so reboot it for now at least, unfortunately is not an option :(
Fixed.
Go on ... put us out of our misery ... what was the problem?
484
