Webcast-Catalyst9k
an odd issue with a 7301
i have a 7301 returned to me by a customer saying that after upgrading the IOS to 12.3(12d) one of the ports ceased functioning. i am only beginning my testing but was puzzled when i could not even console into the router until finally setting the stopbit in the console as 2 instead of 1. Examining the configuration guide they indicate the stopbit should be 1. Is this somewhere configurable on the router or how otherwise might it have been changed? any ideas are welcomed!
thanx!
Wm
Re: an odd issue with a 7301
Wm,
It is configurable on the router.
conf t
line console 0
stopbit 2 ( options are 1,1.5,2)
Youc an change it on your router, set it tp 1 and you wil be fine.
regards,
-amit singh
hi
can u revert whether you have changed only the stop bits or other parameters (like baud rate,data bits,parity) too ?
AFAIK if the config register values are different it will result something like what you are facing now.
you can also change the stop bits under the line con 0 mode where u got the options for 1 or 2 where 1 is set by default..
regds
well that is the odd thing - beneath the line con 0 it is set as
stop bits 1
which is of course the default - but still i needed to use 2 to actually get into the console! can you set the stop bits in the confreg or only the baud rate?
thx,
William
Please paste the output of " Show ver "
regards,
-amit singh
here is the output of both show ver and sho run
thanx for the help!
~Wm
Router#show version
IOS (tm) 7301 Software (C7301-IS-M), Version 12.3(12d), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 31-May-05 20:49 by ssearch
Image text-base: 0x60008AF4, data-base: 0x61C0A000
ROM: System Bootstrap, Version 12.3(4r)T2, RELEASE SOFTWARE (fc1)
BOOTLDR: 7301 Software (C7301-BOOT-M), Version 12.3(12), RELEASE SOFTWARE (fc3)
Router uptime is 1 hour, 28 minutes
System image file is "disk0:c7301-is-mz.123-12d.bin"
cisco 7301 (NPE) processor (revision E) with 983040K/65536K bytes of memory.
Processor board ID 74826111
SB-1 CPU at 700MHz, Implementation 1, Rev 0.2, 512KB L2 Cache
1 slot midplane, Version 2.0
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
3 Gigabit Ethernet/IEEE 802.3 interface(s)
509K bytes of non-volatile configuration memory.
62720K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
32768K bytes of Flash internal SIMM (Sector size 256K).
Router#sh run
Building configuration...
Current configuration : 770 bytes
version 12.3
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
media-type rj45
negotiation auto
interface GigabitEthernet0/1
ip address 10.25.2.34 255.255.255.0
duplex auto
speed auto
media-type rj45
negotiation auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
media-type rj45
negotiation auto
ip classless
no ip http server
gatekeeper
shutdown
line con 0
transport preferred all
transport output all
stopbits 1
line aux 0
line vty 0 4
end
Router#
hi
The config register whichs 0x2102 seems fine which is the default value and which requires 9600 , 8 , none , 1 , none for the hypertrm to console onto your device.
and again the stopbits seems to set as 1 in your case which also looks ok ,but do revert with all these settings are you still prompted to key in 2 as your stop bits to get onto the box ??
We do have around 5 7301 boxes working in our network in which we didnt face this kinda weird probs..
regds
William,
Its an interesting one. We thought that it could be config-register problem or the Stopbits setting problem.
What happens if you take the commands under the Line con 0 out ??? Try that and revert..
According to one of the cisco DOCS, whihc again bring out some of the confusion:
The Cisco IOS software supplies the following default serial communication parameters for terminal and other serial device operation:
* 9600 bits per second (bps) line speed
* 8 data bits
* 2 stop bits
* No parity bit
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_configuration_guide_chapter09186a00800d984e.html#1000903
Take the settings under the line con 0 out and revert.
regards,
-amit singh
okay. i performed a write erase then found that the stopbit variable was still set under the line con 0 and aux lines. I then removed it from both and rebooted. I now find that I can get console using either stopbits = 1 or 2! and that the stopbits 1 command has reappeared in the line con 0 and aux sections. Odd...but at least i can access the router!
thanx!
William
235
