Analog modem module poblem
I got a 3661 router with slot 1 and 2 used up with a 4port serial network module each. I recently bought a 16 port analog modem module, but when I install it on Slot 3 the router couldnt detect it. Do I need to enable a command ?
Here is the version of my IOs and the slots currently in use
IOS Version
ITC_Router_3660#sho ver
IOS (tm) 3600 Software (C3660-I-M), Version 12.2(5a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Thu 04-Oct-01 22:21 by pwade
Image text-base: 0x600089C0, data-base: 0x60A60000
ROM: System Bootstrap, Version 12.0(6r)T, RELEASE SOFTWARE (fc1)
ITC_Router_3660 uptime is 23 minutes
System image file is "flash:c3660-i-mz.122-5a.bin"
cisco 3660 (R527x) processor (revision 1.0) with 28672K/4096K bytes of memory.
Processor board ID JAB0549801G
R527x CPU at 225Mhz, Implementation 40, Rev 10.0, 2048KB L2 Cache
Bridging software.
X.25 software, Version 3.0.0.
3660 Chassis type: ENTERPRISE
1 FastEthernet/IEEE 802.3 interface(s)
8 Serial network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
Show Diag
ITC_Router_3660#sho diag
c3600 Backplane EEPROM:
Hardware Revision : 1.0
Top Assy. Part Number : 800-04740-02
Board Revision : C0
Deviation Number : 0-0
Fab Version : 02
PCB Serial Number : HAD04471SGX
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Chassis Serial Number : JAB0549801G
Chassis MAC Address : 0007.85bf.34c0
MAC Address block size : 112
Manufacturing Test Data : 00 00 00 00 00 00 00 00
Fab Part Number : 28-2651-02
Number of Slots : 6
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 C8 41 01 00 C0 46 03 20 00 12 84 02
0x10: 42 43 30 80 00 00 00 00 02 02 C1 8B 48 41 44 30
0x20: 34 34 37 31 53 47 58 03 00 81 00 00 00 00 04 00
0x30: C2 8B 4A 41 42 30 35 34 39 38 30 31 47 C3 06 00
0x40: 07 85 BF 34 C0 43 00 70 C4 08 00 00 00 00 00 00
0x50: 00 00 85 1C 0A 5B 02 01 06 FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Slot 0:
C3600 Mother board 1FE(TX) Port adapter, 1 port
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
PCB Serial Number : JAB05440FND
Processor type : 34
Top Assy. Part Number : 800-05293-04
Board Revision : C0
Fab Part Number : 28-3234-02
Deviation Number : 65535-65535
Manufacturing Test Data : FF FF FF FF FF FF FF FF
RMA Number : 255-255-255-255
RMA Test History : FF
RMA History : FF
Field Diagnostics Data : FF FF FF FF FF FF FF FF
0x00: 04 FF C1 8B 4A 41 42 30 35 34 34 30 46 4E 44 09
0x10: 34 40 00 DA C0 46 03 20 00 14 AD 04 42 43 30 85
0x20: 1C 0C A2 02 80 FF FF FF FF C4 08 FF FF FF FF FF
0x30: FF FF FF 81 FF FF FF FF 03 FF 04 FF C5 08 FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00
Slot 1:
Mueslix-4T Port adapter, 4 ports
Hardware revision 1.1 Board revision J0
Serial number 26536025 Part number 800-02314-02
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
0x20: 01 54 01 01 01 94 E8 59 50 09 0A 02 00 00 00 00
0x30: 98 00 00 00 01 11 29 00 00 05 FF FF FF FF FF FF
Slot 2:
Serial number 26553974 Part number 800-02314-02
0x20: 01 54 01 01 01 95 2E 76 50 09 0A 02 00 00 00 00
0x30: 98 00 00 00 01 10 17 00 00 05 FF FF FF FF FF FF
Hope somebody helps
Silver
Re: Analog modem module poblem
We do not need to enable any command for the card to be recognized, it should show up in the sh diag / sh ver / sh run (line x y).
Try moving the card to another unused slot, if it still is not recognized then it could be a bad NM-16AM card.
Thanks, Mak.
Does analog modem module have to be installed in a specific slot ? For eg. It can only run when it is installed on slot 1.
Most of the exmple shows that it is on slot 1
No it doesn't have to be..You can install it in any slot. Visit following url for more
http://www.cisco.com/warp/public/107/hw_async.shtml
Mostly you may have the bad card. Try to install it on other slot to eliminate the slot problem on chassis.
check enable LED on the card , is it ON ?
Thank you all for your response. I think I didnt really push the module so that it connects with the connector inside the router.
It works now
thank
102
