Webcast-Catalyst9k
another 2610 question: trunking on the ethernet interface
You an now setup trunking on the ethernet interface of the 2610 router. I am running 12.2.11T IP Plus
I am running a trunk between the router and a cat 3524 switch, the configs all work ok on a standard Fast ethernet interfaced router.
The address of the switch is on the default vlan 1
I found that devices on connectto Vlans 55 and 56 on the switch could ping the router ok, but devices on the default vlan could not, nor could the switch ping the router.
It seems to me that the native Vlan does not work on a dot1q trnk when configured on a 2610 ethernet interface... comments please.
interface Ethernet0/0
no ip address
full-duplex
interface Ethernet0/0.1
description Management Vlan 1 subnet 57 kelso
encapsulation dot1Q 1 native
ip address 172.16.57.254 255.255.255.0
no ip redirects
no ip mroute-cache
interface Ethernet0/0.55
description Data Vlan subnet 55 Kelso
encapsulation dot1Q 55
ip address 172.16.55.254 255.255.255.0
traffic-shape group 110 64000 8000 8000 1000
traffic-shape group 111 64000 8000 8000 1000
h323-gateway voip bind srcaddr 172.16.55.254
interface Ethernet0/0.56
description IP Phone Vlan subnet 56 Kelso
encapsulation dot1Q 56
ip address 172.16.56.254 255.255.255.0
no ip redirects
1 REPLY
Re: another 2610 question: trunking on the ethernet interface
You have bug CSCea47421. Here are the release notes. You will have to use the workaround to get it to work.
Release-note:
Trunking is broke after configuring 'Native' keyword on router subinterface.
Trunk is up/up but no data will pass.
Ex. non-working config.
no ip address
full-duplex
interface Ethernet0/0.10
encapsulation dot1Q 10 native
ip address 10.1.1.2 255.255.255.0
end
Workaround
***Ex. working config.***
full-duplex
end
I hope this helps!
245
