another question about ethernet encapsulation
hey again
is there a command that can change the ethernet encapsulation in a router -
for example let say i want to change the encapsultaion from 802.3 to arpa
in the ethernet interface.
is it possible ?
if there are two routers, or two computer with not the same ethernet encapsulation , can the communicate ?
if i have one computer talking with 802.2 snap and other with 802.3 can they
"understand each other "
by the way when a computer ( not a router) sending a frame - what is the default frame that is use. ( in ip protocol) - is it 802.3 or 802.2 snap
and again can i change it from one encapsulation to another
( again computer not router)
thank you for your passion
--bye--
1 REPLY
Re: another question about ethernet encapsulation
In theory, it should be possible to change the encapsulation. However, the standard for IP is to use Ethernet_II encapsulation. Most systems will not allow you to change this. There is no reason to do this either.
Two devices talking IP, but using a different encapsulation will not be able to communicate.
Hope this answers your questions.
80
