Make sure you have the requried bootstrap version. Always check the releas notes and do bug scrub using bug tool kit. Typically you should not have issues with your upgrade. I suggest that you go 6.3.7 instead of 6.3.6. Always it is recommended to go to the latest maintenance image on a train if available.
