Any issues on 6509 going from 5.5(1) to 6.3.(6)?
1 REPLY
Re: Any issues on 6509 going from 5.5(1) to 6.3.(6)?
Make sure you have the requried bootstrap version. Always check the releas notes and do bug scrub using bug tool kit. Typically you should not have issues with your upgrade. I suggest that you go 6.3.7 instead of 6.3.6. Always it is recommended to go to the latest maintenance image on a train if available.
84
