appletalk issue
hi!
our sites use all 3COM backbone and access switch.
they use about 80 Macintosh pc.
but , if use cisco 2950 switch instead of 3com switch , mac pc do not see another server ( another vlan)
routing is good , but i think Layer 2 ' issue.
thanks
1 REPLY
Re: appletalk issue
Can you ping the server from the mac PC.
Which device is doing the routing and how its is setup.
Let us know more info on this. You are replacing all 3com switches with cisco or only one.
More info required.....
-amit singh
107
